Problem with erasing and overwriting FLASH data
Nickname400_O
Posted on June 15, 2013 at 12:58
After writing in FLASH using FLASH_ProgramWord(uint32_t Address,Data). I can't overwrite that address data completely using FLASH_ProgramWord(Address,0xFFFFFFFF) or FLASH_ProgramWord(Address,Newdata);.
In case of erasing it with FFFFFFFF, data on that address does not change.
In case of overwrite with other data, it only replace it with some wrong data.
Posted on June 15, 2013 at 13:34
Cross Posted
I can't erase that Address data by using FLASH_ProgarmWord(uint32_t Address,0xFFFFFFFF).
Because it doesn't work that way, you have to erase a whole SECTOR (16,64 or 128KB depending on the address range).
