Power Source Solar Powered (stm32l152 discovery)
asv-lab
Posted on August 31, 2014 at 18:51
I make the charger from the solar panels with automatic orientation to the sun. There is a problem after device reset, reset to zero RTC. What can cause, reset clocks?
http://youtu.be/CaiQAkqU08w?list=UUrYD2NXH5n3BeOBhFIlsMBQ
Posted on August 31, 2014 at 19:37
Powering or coding?
I'd perhaps not put all the weight cantilevered onto the servo shaft, and had a shaft/bearing arrangement with a belt/gear drive from the servo.
asv-lab
Posted on August 31, 2014 at 20:57
Reset causes the program. after resetting cpu  the rtc  reset to zero.
This experimental device for debugging codes. )) I will remake  mechanics later. thanks for the advice
