PortB Pin 8 not pulling down
ikutakun
Posted on November 24, 2010 at 11:59
Posted on May 17, 2011 at 14:16
More likely you have some thing external driving PB.8, the pull up/down is going to be pretty weak.
Set the pin floating and scope it.
ikutakun
Hi clive,
Thanks for your answer. I have checked the connection. It looks like it's stuck at high. I didn't find anything that is wrong with the PCB trace. Do you think I can add an external pull down resistor to this pin to put it down?
Victor
