P-NUCLEO-LRWAN3 ETHERNET: DHCP TO STATIC modify problem
LProj.1
I am using a P-NUCLEO-LRWAN3 product.
1- At the beginning, I need to change  ETHERNET: DHCP to STATIC. Later, I wanted to change to DHCP again with this code: 13:12: AT+IP= DHCP
AT+IP= DHCP
+IP: NETMASK ERROR
2- I can not use Loriot server due to error attached. Do you have any other suggestion for P-NUCLEO-LRWAN3 online server ?
Can I ask your support about this two problems ? I have attached the related screenshots.
BR
0 REPLIES 0
