OPI Driver ERROR 231
aymen
Posted on September 30, 2013 at 13:19
hi,
I am using STM32RBT6 and RIDE7,
when I try to debug there is an error ''unable to reset device and enter to debug mode''
can you help me?
frankmeyer9
Posted on September 30, 2013 at 14:15
Correct me if I'm wrong, but AKAIK the Raisonance toolchain supports only it's own debug adapter. So the Raisonance forum might be a better place to ask.
Posted on September 30, 2013 at 15:23
What's your current code doing that could compromise the SWD/JTAG interface? Reconfigured GPIO, DMA, WFI?
If it's a problem with user code, then set BOOT0 High so it starts in the system loader which should be reasonably safe to program from.
aymen
Posted on September 30, 2013 at 15:37
the problem is solved, it was at welding of microcontroller.
