older versions of cubemx and cube firmware libraries
leet1
Posted on November 21, 2016 at 15:39
Is there somewhere I can obtain older versions of cubeMX and the cube firmware libraries?
since ST doesn't seem to maintain backward compatibility, I need cubeMX v4.14.0 and the stm32f4 cube library v1.11.0
slimen
Posted on November 21, 2016 at 15:49
It's recommended to use the recently version of CubeMx/Firmware which contains bug fixes and enhancement.
It's not possible to obtain older versions of CubeMX. But, it's possible for cube firmware libraries to install older versions from STM32CubeMx tool: Help > Install New libraries (you find all Cube releases)
leet1
Posted on November 21, 2016 at 17:13
Hi
Thank you for your response.
The download from CubeMX does not work, I get and error at the end of download (see screenshot)
installing 'From Local' works fine, i'm using v4.0
________________
Attachments :
Capture.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtmV&d=%2Fa%2F0X0000000aWp%2FB75UIbMigNSUxp3kP911hHkcGzoe8QTCqjQ4aQy_H5k&asPdf=false
Posted on November 21, 2016 at 17:19
This is a mirror of
https://drive.google.com/open?id=0B7OY5pub_GfIMmFkblJIRUhSd0U
