Newbie here.... I need to take a fast ramp to a bluetooth controlled temperature measurement and a PID temperature controller.....
TKeel
can somebody give me a point to an eval board set that I could use with perhaps STMCube toolset?
Thanks so much for your kind help and for the kickstart.
MikeDB
Lead
A much faster way would be to look on Hackster.io and look for similar projects, possibly using an STM BluePill. I'm sure you'll find most of what you need already done.
And STMCube is not a quick kickstart - if you want small, quick and dirty use STM32duino which is a bit like Arduino.
There are also some projects in @Share Your Projects​ space.
Pdal.1
Thanks for sharing this
