Latest Version of IAR Emedded Workbench & CMSIS / Std Perph Library
bengriffiths9
Posted on May 06, 2011 at 12:17
cschumann
Posted on May 17, 2011 at 14:34
We experienced the same problem. If you change the conflicting declarations in core_cm3.h from uint8/16/32_t to  unsigned char/short/long IAR will compile your project without errors/warnings.
Best regards,
Carsten Schumann
frieder
also having the same problem when upgrading from 6.10 to 6.20.
Copying intrinsics.h from 6.10 to 6.20 (C:\Program Files\IAR Systems\Embedded Workbench 6.0 Kickstart\arm\inc\c\intrinsics.h) also fixes the conflicts (maybe causing other problems later).
Greetings,
Frieder
