Is the bootloader permanent?
inode
Posted on June 01, 2009 at 17:28
inode
Posted on May 17, 2011 at 13:13
Is the serial bootloader in STM32 models permanent or is it just one time usable, in other words does your own firmware write it over?
The reason I ask is that Luminary Micro calls ''one time bootloader'' as ''Serial Flash Loader'' and ''real'' bootloader as ''bootloder'' and I see serial flash loader mentioned in STM32 datasheets.
16-32micros
Our UART Bootloader as described in AN2606 is permanent and is located in a ''ROM Area'' and can never be re-programmed by software or re-writed again.
Cheers,
STOne-32.
inode
Great! Thank you.
