__IO, gcc and core_cm0.h
‎2015-03-03 4:13 PM
I am porting the Custom HID demo project that is included with STM32_USB-FS-Device_Lib_V4.0.0 library to work with my gcc-based toolchain. I have previously successfully ported other code (specifically, from Olimex for the EW-ARM 5.11 toolchain) to work with my toolchain with little difficulty. Both the new code and the previously ported code uses the __IO directive in places, and the library routines such as stm32f10x_adc.c also use it and were properly compiled and built in the previously ported code. However, the new code throws a large number of errors when it tries to compile usb_pwr.c. The first such error is: In file included from ./inc/usb_lib.h:37:0, from src/usb_pwr.c:31: ./inc/usb_regs.h:617:1: error: unknown type name '__IO' ./inc/usb_regs.h:617:22: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'wIstr' In file included from ./inc/usb_lib.h:39:0, from src/usb_pwr.c:31: I can make these and a large number of my subsequent errors go away by putting #define __IO volatile in usb_pwr.c. However, this makes that function non-standard which I don't want to do. After much searching I found that an identical definition is provided in the CMSIS/Include directory in core_cm0.h. Where and how is this header normally included in the demo code? Or is it included in the toolchain configuration? It must be included somewhere to compile the demo. I would like to duplicate that inclusion in my port or toolchain without modifying the distributed STM32_USB-FS-Device_Lib_V4.0.0 because that might give me major issues when that distribution is upgraded. Any help would be appreciated. Best regards, Peter- Mark as New
‎2015-03-03 4:50 PM
On F4 parts, stm32f4xx.h #include's ''core_cm4.h''
On F1 parts, stm32f1xx.h #include's ''core_cm3.h''Up vote any posts that you find helpful, it shows what's working..
‎2015-03-03 6:18 PM
Thanks, clive1. Most helpful.
‎2016-11-06 11:26 PM
What does it means accordance with header file?Afterwords, if you get , warning: control reaches end of non-void function [-Wreturn-type]This time would you mean,functions are returning without providing a value when one is expected.?
Kindly answer please.RegardsHasan- Mark as New
‎2016-11-07 12:39 AM
The first suggests one or more include file is not being pulled, perhaps due to the absence of a define or other selective compilation.
The second suggests an int foo() function has multiple exit paths and one of those doesn't return an int.Up vote any posts that you find helpful, it shows what's working..
‎2016-11-07 1:03 AM
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
/* USER CODE END 6 */
#endif
Most funny thing is, all errors come from header files, even I include by # in main.c!I want to ask you , if I removed some folder ( previous project) which has similar include files that already exists in project properties path in C, would I face any problem?
RegardsHasan
