Interrupt Disable, ??/
JHERI
Hello
using HAL libraries is it possible to disable for a short time an external interrupt pin ??
I have had a look in the HAL GPIO files and can not see anything useful
Just want to disable while a trigger a debounce timer, there must be a way of just disabling the external gpio interrupt pin
any help will be very much appreciated
Would expect it could be done at the EXTI level, or NVIC. The Reference Manual should describe the registers for the former.
Use NVIC_DisableIRQ and NVIC_EnableIRQ, passing your IRQ as a parameter, example:
NVIC_DisableIRQ(EXTI15_10_IRQn);
JHERI
Thank you
