Illegal address on stm32f3discovery in debug mode
Options
2013-11-06 2:29 AM
Posted on November 06, 2013 at 11:29
Hi all,
I'm starting the debug with Keil uVision V4.72.10.0. Compile and programming is OK, but when I start the debug session the output window show the next error message:Internal DLL ErrorInternal command error
*** error 57: illegal address (0x08000000)I've set the target option as indicated in the
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00062662.pdf
on page 28 Fig 32.Can you help me?Thanks and regards
Options
2013-11-06 4:30 AM
Posted on November 06, 2013 at 13:30
Have you tried using the Template project? Does that work?
Make sure not to use the ''ST-Link Deprecated'', that the Debug/Setup dialog shows it finds the device, FW version, SWD, etc. Make sure you've loaded current drivers (\Keil\ARM\ST-Link ?) It might be helpful to provide screen shots of your configurations.
