I2C slave error
levypantsoem
Posted on March 01, 2009 at 11:28
I2C slave error
levypantsoem
Posted on May 17, 2011 at 13:04
I have a problem with the I2C slave read (or transmit) operation.
Sometimes, when the master does a Read operation in my device, it only reads FF's.
It seems as if the clock streching wasn't working (it's set), so the master is just reading the SDA pull-up. It only happens sometimes, so maybe it's an interrupt related issue.
Has someone experienced this before?
Thank you
