I want to design a pcb with STSPIN32F01. To program this IC I do not want another controller like in the eval board. How can I program this IC? Can I use motor work bench?
NRao.1
You should be able to program with an external ST-LINK via the SWDIO/SWCLK pins
https://www.st.com/resource/en/datasheet/stspin32f0.pdf
Thanks Clive did exactly that and it worked like a charm.
