I had a certificate problem when using B_L475EIOT01A
wxie
I followed the getting started tutorial, when I pressed the reset button then the user button, the uart terminal indicated failed to provision certificate -1 as the attachment. Could you some tell me what's the problem
0 REPLIES 0
