how to swith to 72Mhz ?
manes69692
Posted on February 01, 2009 at 06:15
manes69692
Posted on May 17, 2011 at 13:01
Hi
I trying to switch my board to 72Mhz , but I think I do something wrong , because I'm also using usart1 at 9600bd , but my baudrate is not correct
When just turning on my external xtal of 8Mhz , the baudrate is correct.
What is the correct sequence for switching to pll ?
Best Regards ,
Ronny
BTW this is the code I'm using :
// switch to 72MHz
RCC_CR=0x00010083; //enable the 8Mhz crystal
while (!(RCC_CR)&0x00020000); //wait for hse ready
RCC_CFGR=0x00000001; //set the 8Mhz crystal as clock source
RCC_CFGR=0x00010001; //set the 8Mhz crystal as pll source
RCC_CFGR=0x001d0401; //pll*9
RCC_CR=0x01010083; //enable the pll
while (!(RCC_CR)&0x02000000); //wait for pll locked
RCC_CFGR=0x001d0402; //set pll as system clock source
disirio
Hello, I am using this initialization sequence, it works for both 48 and 72 mhz:
http://chibios.svn.sourceforge.net/viewvc/chibios/trunk/demos/ARMCM3-STM32F103-GCC/board.c?revision=634&view=markup
Just look at the hwinit0() function.
The various constants are defined here:
http://chibios.svn.sourceforge.net/viewvc/chibios/trunk/demos/ARMCM3-STM32F103-GCC/board.h?revision=703&view=markup
regards,
Giovanni
manes69692
regards,
Giovanni
Thanks Giovanni !
Your code works perfect , I'm gonna figure out now , what I did wrong
Thanks again
Ronny
