How to read/write the data? I used the Armasm V6.13.1 as compiler.
DChie.1
Try.S
    AREA  RESET, DATA, READONLY
DCD 0x20001000   ; stack pointer value when stack is empty
DCD Reset_Handler ; reset vector
ALIGN
AREA Init, CODE;, READONLY
ENTRY
Reset_Handler  PROC
    EXPORT Reset_Handler
    IMPORT Start
 LDR  R0, =Start
 BX   R0
    ENDP
      END
Main.S
AREA |.text|, CODE
  export Start
Start  PROC
 LDR  r0, =SRC
 LDR  r1, =DST
 MOV  r4, #0x03
Repeat
 LDR  r2, [r0], #0x04
 STR  r2, [r1], #0x04
 SUB  r4, r4, #0x01
 CMP  r4, #0x01
 BNE  Repeat
loop
      B    loop
  align
 ENDP
    AREA  MyData, DATA, READWRITE
SRC      DCD 0x1234,0x5678
DST      DCD 0x1111,0x2222
      END
0 REPLIES 0
