KVenk.2
How to print logs for B-L475E-IOT01 board ?
  • November 28, 2018
  • 583 views
I am using STM32CubeMx to generate default files to build with Makefile. I edited the main.c to print some logs using printf. I am unable to see the same logs in the serial. Am I missing anything ?
    Tesla DeLorean
    Guru
    November 28, 2018
    Evidently something
    Confirm the configuration of the clocks, peripheral and pins. Inspect registers in debugger.
    Check USART via simple string output test, NOT using printf/puts/putchar
    KVenk.2
    KVenk.2Author
    I tried directly to write into the USART1 using the below method
    HAL_UART_Transmit(&console_uart, (uint8_t*)string, strlen(string), 0xffffff);
    It is working fine. But how to redirect the standard I/O to the same port ? I am naive in this. Any Help could be appreciated
