How to determine from which channel the capture took place?
Siragh ASUTP
Posted on May 01, 2017 at 08:06
Hello. I use stm32a4 and timer2 (channel 3 and channel 4) in capture mode. How to determine from which channel the capture took place?
4 REPLIES 4
Posted on May 01, 2017 at 18:11
Check the TIMx->SR it flags which channel(s) captured.
Use the TIMx->SR = ~CLEARTHISBIT; // not the &= RMW form
void TIM2_IRQHandler(void)
if(TIM_GetITStatus(TIM2, TIM_IT_CC3) == SET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC3);
Cap3 = TIM_GetCapture3(TIM2);
if(TIM_GetITStatus(TIM2, TIM_IT_CC4) == SET)
TIM_ClearITPendingBit(TIM2, TIM_IT_CC4);
Cap4 = TIM_GetCapture4(TIM2);
Posted on May 01, 2017 at 18:12
Duplicate Thread
https://community.st.com/0D50X00009XkdeMSAR
Siragh ASUTP
Posted on May 16, 2017 at 06:22
Thanks for the answer. I use the HAL library. Can you give an example for this library?
Posted on May 16, 2017 at 18:46
No
