How to determine from which channel the capture took place?
Siragh ASUTP
Posted on May 01, 2017 at 08:49
Hello.
I use stm32a4 and timer2 (channel 3 and channel 4) in capture mode.
S.Ma
Principal
Posted on May 01, 2017 at 12:06
Have a look at the reference manual to find out in the status register the flag for each capture register which is set by hardware. Usually in a control register, there is an interrupt enable to trigger an ISR to process all captures/compares associated to a timer. Don t forget to clear the status flag quickly before the next event...
Posted on May 01, 2017 at 18:13
https://community.st.com/0D50X00009XkdeKSAR
