How to count cycles with the ARM simulator
kostyak
Posted on July 17, 2008 at 17:02
kostyak
Posted on May 17, 2011 at 12:23
Hi !
How can I count execution cycles with the Keil MDK ?
How can I do this with the simulator. Is the simulator
count reliable ?
I'm using the STM32 Keil Board.
regards
Manfred
16-32micros
Hello Manfred,
I've tried the same and sometimes a get some trouble with Keil simulator and I think that it is not reliable with some instructions like STR and LDR. This discussion has pointed this, some time ago :
http://www.st.com/mcu/forums-cat-6133-23.html&start=30
You can simply use the systick counter on real evaluation board of STM32 It is more accurate and can provide you the exact CPU cycles for your becnhmark routines. Regards STOne-32
john
How would you use the systick to count CPU cycles ?
Would this work over a STOP mode (ie. no cycles are counted) ?
Thanks,
John.
