how to capture signal at rate 3 mbit/s
cellulenumerique
Posted on December 09, 2011 at 23:23
hi,
i have a signal to rate at 3mbit/s. The clock and signal are separate on two line.
i tried to use connect EXTI on the clock. When i have a interrupt, i read the PIN where the signal's. This solution don't work.
So, i want tu use the TIM external clock, and Input capture for read my signal. but this solution is more complicated.
have you other idea?
4 REPLIES 4
Posted on December 09, 2011 at 23:38
SPI Slave, or Synchronous USART
cellulenumerique
Posted on December 10, 2011 at 10:18
My signal is continus and isn't a SPI format. is it possible to use the periph SPI for other signal type?
 if i use the synchronous USART,
the
start bit and
stop
going to
bother me
because my
signal
will not have
the right structure
Posted on December 10, 2011 at 14:17
You say you have a clock and data signal, would seem like a good fit. Perhaps you need to be more specific.
cellulenumerique
Posted on December 10, 2011 at 22:40
I read more the datasheet and i think your solution is good.
I will tried this solution, monday.
