zamzoni
how long cr2032 battery can backup rtc and ram?
  • March 2, 2013
  • 1021 views
Posted on March 02, 2013 at 15:01
If I attach cr2032 battery to STM32F103RBT6, how long it can run the rtc and backup the content of ram?
    waclawek.jan
    Posted on March 02, 2013 at 15:34
    As the self-discharge of lithium primary cells is negligible, simply divide the cell's capacity (cca 225mAh) by the RTC's current consumption (see datasheet).
    jj2
    Posted on March 03, 2013 at 23:09
    And - should either the MCU or external circuit be sufficiently clever - you likely can avoid any such battery drain while the ''main'' power is supplied.
    Depending upon power-on vs power-off duty cycle - this may/may not be a big deal...
