Hi i just got got a nucleo st32 f303K8T6 and i can not seem to connect it to my laptop. I do not even get to see the device being plugged in. I tried installing drivers and that still did not work. If anyone can help please let me know.
JGjok.1
4 REPLIES 4
Try a different cable, charging cables probably won't work.
But the power goes into the board as it flashes a red light or that doesn't mean anything.
Charging cables generally succeed in connecting power, communications not so much. Like I said try using a different cable
It might contain a demo firmware that flashes some LEDs.
Try plugging it in a USB2 port or a powered USB2 hub, might work better as USB3.
But check the cable first, does it work with some other USB device, e.g. a smartphone?
