GDB Connection Timeout
gapryun
Posted on December 21, 2013 at 14:53
I used to the St-write to burn .bin to the STM32F4 and saw the message which I expected. Now, I hope to understand how GPIO init. Hence, I use OpenOCD and arm-none-eabi-gdb to do that. Here, it is my process.
$ minicom
$ openocd -f /opt/openocd/share/openocd/scripts/board/stm32f4discovery.cfg
$ arm-none-eabi-gdb main.elf
(gdb) target remote :3333
(gdb) :3333: Connection timed out.
How do I check the port of OpenOCD? Why does it occur timeout?
#openocd-gdb-connection-timeout
alfbaz
Posted on December 22, 2013 at 03:52
try target remote localhost:3333
gapryun
Posted on December 22, 2013 at 12:33
(gdb) localhost:3333: Connection timed out.
It's same.
xacc
Posted on December 23, 2013 at 07:13
If it is intermittent, try another USB port. I kept on getting timeouts restarting a debug session in Atollic till I finally found a USB port that did not do it any more.
