2014-07-28 2:46 AM
Hi everyone,
I have to design an IIR Filter and i want to use the DSP library provided. I'm new to digital filtering and i want some help to understand the biquad function in the library. I found an exemple in the arm_graphic_equalizer_exemple_q31 in the DSP Lib. I'm using MATLAB to design my filter with FDA Tool, but still it seems to generate different My questions are : - How can I generate coeficients with MATLAB to be use in the Biquad cascad filter. - Any help about understanding the Biquad function, or can soemone provide me an easy example of using it. Sorry about my bad English Thank you in advance, Luc #digital-filter-iir-biquad2014-07-29 6:47 AM
Well Luc , Biquad filter is simply a second order filter , meaning the denominator will always be in the form (S^2+aS+b) , but the numerator will differ according to the type of filter u would want (LP , HP , BP , or BS) . To be honest I have not heard of the word ''Biquad'' in the Digital Filtering , only in analog designs , but speaking of Digital filters , u would use FIR or IIR . I used Window Function approach to design Digital Filter . First you choose a Window function (in the Frequency Domain) , say a simple gate (or rectangular) , limited by the cut off frequency , then you get the Frequency Domain expression , then get the inverse FT , then implement the resulting function (Time Domain) as the filtering function .
Good Luck2014-07-30 4:44 AM
Thank you for your response and your advices. I want to design some BP IIR filters. It's ok now i found a solution to calculate the coefficients for using the function arm_biquad_cascade_df1_init_q31 provided in the DSP library. I'm using MATLAB to design my filter and export de SOS martrix. Thank's a lot for your time
