FAT system and SD Card, ARM STM32F103RBT
vinicius_acvasconcelos
Posted on January 29, 2009 at 16:14
13 REPLIES 13
mdeneen
Posted on May 17, 2011 at 12:58
Check this thread:
http://www.st.com/mcu/forums-cat-6318-23.html&start=10
It works quite well!
I`m using ARM STM32F103RBT6. I`m able to record and read data in SD Card with a raw format(Using simple SPI).
But I have to use the FAT system because after recorded the card will be read on a PC.
Anyone have any library, documentation or example using FAT to help me?
Thanks,
Vinícius
jaroslaw2
I've post working example hire:
http://www.st.com/mcu/forums-cat-7702-23.html&start=10
Quote:
On 12-01-2009 at 20:40, Anonymous wrote:
Check this thread:
I tried your Code :-[ . First I had to change all ''SPI_FLAG_TXE'' to ''SPI_I2S_FLAG_TXE''
After that I was able to compile the code.
But Didn't Work, I start the debug and the CrossStudio tell: Error reading Memory.
Someone has any idea to make this code works?Has it?
[ This message was edited by: vinicius_acvasconcelos on 14-01-2009 19:32 ]
[ This message was edited by: vinicius_acvasconcelos on 14-01-2009 19:34 ]
Thanks for the example:-D. I tried your exemple, but the CrossStudio give a message:
'printf.c:(.text+0x30): undefined reference to `__putchar'
Its the only problem, all the rest seems to work pretty well.
Could you have any idea how can I solve this problem?
slawcus
Read this:
http://www.rowley.co.uk/documentation/arm_1_7/hcc_customizing_putchar.htm
[ This message was edited by: slawcus on 15-01-2009 23:21 ]
Quote:
On 15-01-2009 at 23:21, Anonymous wrote:
Read this:
Thanks!:-D Its solve the putchar problem, now I'm can compile the code. Today I will test with the Sd Card, and will see if the code realy works.
I Fixed the __Putchar problem, but your code give a HardwareFault Excepition. What I have to do to this write the data on SD Card in Fat System??? :o
gabrielbonato
I'm problem, not function fat file system examples.
Please help!
