Chandan Bhatia1
Error: arm-none-eabi-objcopy:App.bin[ExtFlashSection]: No space left on device
 Hello, I am building both bootloader and application firmware. Post generating .elf and hex file, I am generating .bin file for both and combining them to make single flashable .bin file with padding and all with help of command for .bin file geneation.
arm-none-eabi-objcopy "${BuildArtifactFileBaseName}.elf" App.bin -O binary
Everything works fine till I use external flash for application. When I did same work for application with external flash, I m getting below error.
When I removed .bin file generation code, Everything worked fine.
I am not sure about issue. Please suggest.
    Tesla DeLorean
    Guru
    November 16, 2020
    Suggests the memory regions used are far apart, and the resulting .BIN consequently will be very large trying to span the difference in the address space.
    Chandan Bhatia1
    @Community member​ Ok , How should I solve it?
    Chandan Bhatia1
    Basically I need one flashable file which has both bootloader and application code.
