Entering Sleep Mode
YuriCh
Posted on October 30, 2016 at 15:45
Hello!
I am using the STM32L476 for my project and i need to implement a standby mode.
I want to use the sleep mode and i have a few questions:
1. Is there anything else i need to do before entering the sleep mode besides using - HAL_PWR_EnterSLEEPMode(PWR_MAINREGULATOR_ON, PWR_SLEEPENTRY_WFI) ?
2. How can i check whether i entered the LPM properly?
3. Where can i find some detailed documentation regarding these issues?
thank you
Walid FTITI_O
Senior II
Posted on October 31, 2016 at 11:08
Hi cherniakov.yuri,
I see that you ask for how to use and code the Low power mode on the STM32L4 device and not issue description.
For this purpose, I recommend the following resources that give you help on this :
http://www.st.com/content/ccc/resource/technical/document/reference_manual/02/35/09/0c/4f/f7/40/03/DM00083560.pdf/files/DM00083560.pdf/jcr:content/translations/en.DM00083560.pdf
, section 5.5 low-power modes
-Application note
http://www.st.com/content/ccc/resource/technical/document/application_note/9e/9b/ca/a3/92/5d/44/ff/DM00148033.pdf/files/DM00148033.pdf/jcr:content/translations/en.DM00148033.pdf
-Application note
http://www.st.com/content/ccc/resource/technical/document/application_note/5c/cb/90/97/4b/84/4e/81/DM00216518.pdf/files/DM00216518.pdf/jcr:content/translations/en.DM00216518.pdf
And there is several examples in the
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubel4.html
which show how to code and uselow power modes and difference sub-modes at this path: STM32Cube_FW_L4_V1.5.0\Projects\STM32L476RG-Nucleo\Examples\PWR
-Hannibal-
