Documentation Issue - RM0410 Rev 3
Posted on February 25, 2018 at 07:35
The currently posted document does not address the Z-step part, see pg 1899
This document is from Nov 2017, the A and Z steps are discussed in the Oct 2016 errata, along with a reference to RM0410 for details.
http://www.st.com/resource/en/reference_manual/dm00224583.pdf
http://www.st.com/resource/en/errata_sheet/dm00257543.pdf
http://www.st.com/en/microcontrollers/stm32f769ni.html
Posted on February 26, 2018 at 18:19
Also inconsistent naming of RCC_DCKCFGR1 as RCC_DCKFGR1 (pg 152 both names used in notes 2 and 3)
pg 210 uses the wrong naming, and in a dozen or so places in doc, HAL sources refer to
RCC_DCKCFGR1 which makes the most sense.
Makes searching and cross-referencing with in document annoying.
Also DCKCFGR2 used instead of RCC_DCKCFGR2 on pg 212, RCC_xx used consistently for other RCC registers and also in table of registers on pg 215-217
Imen.D
Posted on February 27, 2018 at 17:22
Hello
Turvey.Clive.002
I confirm the missingaboutthe Revision Z and the wrong names that you mentioned.
Your feedback has been reported internally to update the related reference manuals in coming release.
Thanks andBest Regards,
Imen
Imen
Posted on May 16, 2018 at 00:19
Thanks, I see the new manual is posted.
