display address CCM
ludovic Wiart
Posted on September 15, 2017 at 17:52
I try to move some array in CCM on stm32f415.
I modify the ld script with
 CCM_SRAM   (rwx) : ORIGIN = 0x10000000, LENGTH = 64K
.ccmram :
. = ALIGN(4);
_sccmram = .; /* create a global symbol at ccmram start */
*(.ccmram)
*(.ccmram*)
. = ALIGN(4);
_eccmram = .; /* create a global symbol at ccmram end */
}> CCM_SRAM
In my programe I had 2 global array:
char buffer[1024];
char in_ccram_buffer[1024] __attribute__((section('ccmram')));
and I print there address :
printf (' buffer = %08x    in_ccram_buffer = %08x\n',&buffer,&in_ccram_buffer  );
the result is :
buffer = 20001a3c    in_ccram_buffer = 20000ce4
I don't understand why the
in_ccram_buffer isn't in 0x1000.....
#ccm #sram-ccm
Posted on September 15, 2017 at 18:01
Keil example
Look at how the symbol is described in the .MAP file, and why that would end up in SRAM
Posted on September 15, 2017 at 17:57
Use DOT CCMRAM perhaps?
char in_ccram_buffer[1024] __attribute__((section('.ccmram')));
Keil example
Posted on September 18, 2017 at 10:22
Yes It's better with a dot .
Thanks a lot
