Disabling M4 core through CubeProgrammer on Nucleo STM32H755ZIQ: It takes too long
mkel
Hello all, I disabled the M4 core based on the tutorial by ST Employee mEALLEm, I pressed Apply, saw the option byte successfully programmed notification, but I have been waiting for MCU disconnect notification for 20 minutes now. The LD4 keeps blinking greed and red. Is there something I am missing because it should not be this long ?
Thank you
mkel
Hey folks just press reset on your Nucleo. The reset button press is mandatory for uplaod changes like code and this. Thank you for reading
mkel
