2017-03-24 4:52 AM
I see when you change settings on RCC, from internal oscillator to external, both line on .ioc file are setted and the code generated is this:
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSE;
On .ioc file you can find this lines, and i think is not normal
RCC.OscillatorTypeHSE=RCC_OSCILLATORTYPE_HSE
RCC.OscillatorTypeHSI=RCC_OSCILLATORTYPE_HSIRCC.OscillatorTypeLSI=Not only, normaly before generate file, cubemx ask me for enable TIMBase when i use FREErtos, now ask nothing.
Try my ioc. attached
Sorry for my english !
2017-04-28 2:39 AM
Hello marco,
I confirm that the clock issue has been corrected in the latest cubeMx version 4.20.1.
Could you plese upgrade to this version ?
Kind regards
Sirma
2017-03-24 5:17 AM
Please note that the issue on RCC is confirmed and will be fixed in the new patch
to be delivered soon.
Sorry for the inconvenience it may bring.
Imen
2017-03-24 7:50 AM
Ok, please fix also problem of TimeBase for freertos.
2017-04-28 2:39 AM
Hello marco,
Kind regards
Sirma
2017-07-07 2:51 AM
Hello
Origa.Marco
,I tested on CubeMX version 4.22, and I confirm freertos warning is well displayed.
This version will be available in few days from now.
Kind regards
Sirma
