2013-03-18 2:55 PM
I am a beginner in programming with stm32 and i want to know how can i pass data from the accelerometer MEMS to PC via serial part using UART thanks for you help in advance #basic #foundation #prerequisite2013-03-18 3:32 PM
Perhaps you might start by look at some USART, and other examples, in the firmware library for your specific board? Does your board for instance have a serial port connection, and if so to what pins, etc?
Got any experience with other embedded programming, or electronics?2013-03-18 4:12 PM
no i haven't experience in other embedded programming .
I just want to pass data from accelerometer to uart then to pc through the usb port2013-03-18 4:57 PM
Any C programming? What tool chain, or development system, are you using?
What board and chips are we talking about, ST make several dozen? How do you want to send the data, as binary, as ASCII, formatted in some way? Is this a homework project? Work related? Sorry for all the questions, just trying to extract some salient details.2013-03-19 2:45 AM
It's not a homework project,am trying to start my first project on embedded systems
it consists on setting up a road's driving assistant which detectabnormalities and tremors on the road!But i need at the first time to set my threshold which will be chosen through different experiences but i didn't know how to pass the mesures i took from the MEMS accelerometer of stm32F4 to the computer.i use IAR workbench as a developpement environment and i have been programming with c .thanks for help :)2013-03-19 3:42 AM
''It's not a homework project''
So is it for your work, or just your ''hobby''?''trying to start my first project on embedded systems'' Again, do you have any experience with programming in any other field? Specifically, are you experienced in 'C'? Do you have at least a basic understanding of electronics?
2013-03-19 4:24 AM
2013-03-19 5:11 AM
So where's the problem?
Think about how you'd design a program in whatever other field(s) you're familiar with - by breaking it down into manageable chunks...2013-03-19 5:56 AM
To be a little more specific:
There are nice STM32 discovery boards with MEMS sensors, and evaluation boards with RS232. Get the example software for boards you find appropriate, use it as a template, and construct your own application from it. That should get you started quickly.2013-03-19 10:35 AM
If you are using an STM32F4-Discovery board, you'll need to start by wiring up a serial port. For an RS232 connection, you'll need a signal level conversion IC like a MAX232. Not sure how to do this, review some schematics for other boards utilizing the chip, and external connectors.
I have posted several serial port code examples for the STM32F4-Discovery. In order to be successful with your project YOU will need to read the documentation for the board and chips you plan to be using.
