2012-12-18 8:25 PM
Hi all,
I am facing some weird problems related function references. When I write a function that stored in the source file containing the main function, my program works properly. However, if I store it in a different source file and link to main file via ''include'' statement, the program cannot run. Can anybody help me to explain what happens?2012-12-18 9:07 PM
Do you think you have provided enough information for someone else to duplicate your situation?
Suggest you provide some more context, like what tool chain, what errors, how the code looks, how the map file looks, how you've debugged into the code to understand why the transition doesn't work?2012-12-19 4:17 AM
You probably need to ADD the file to your build so the compliler and linker use it. Read the guidance for your particular system or provide details as Clive asked.
