can't enter stop mode when connect an emluator
xleij
when there's no emluator connected, my program works ok. But when I have my emluator connected, my program will immediately recover from stop mode or may even not enter into stop mode?
Do somebody has same experience and give me some ideas?​
Check if there any DBGMCU settings to alter behaviour so it doesn't interfere. Consider different debuggers.
Have your code output flow and telemetry via a serial port so you don't need a debugger to single step or break-point your code. Have a monitor application allowing you to probe internal state, and change level/verboseness of telemetry.
