Can not make RDP work in STM32F429i_Disco
Linda
Posted on March 19, 2015 at 13:38
I can not make RDP work in STM32F429i_Disco
My code is:
            FLASH_OB_Unlock();
            FLASH_OB_WRPConfig(FLASH_WRP_SECTORS, DISABLE);
            FLASH_OB_WRP1Config(FLASH_WRP_SECTORS, DISABLE);
            if (FLASH_OB_Launch() != FLASH_COMPLETE)
            while (1)
            FLASH_OB_RDPConfig(OB_RDP_Level_1 );
            while (1)
            FLASH_OB_WRPConfig(FLASH_WRP_SECTORS, ENABLE);
            FLASH_OB_WRP1Config(FLASH_WRP_SECTORS, ENABLE);
            while (1)
            FLASH_OB_Lock();
Please have a look.
5 REPLIES 5
Posted on March 19, 2015 at 15:44
Focus on the RDP, and not the WRP then. Doesn't FLASH_OB_Launch() reset the processor? Make all your OB related changes, then do the Launch.
Linda
Posted on March 19, 2015 at 18:59
It works now, thanks a lot.
Posted on March 19, 2015 at 19:05
Are you driving the NRESET line?
Linda
Posted on March 23, 2015 at 19:31
Dear Sir,
Is possible to set protection level by sectors?
For example, I want to set sector 19 as level 2 RDP, the rest as level 1 RDP by code?
Thanks a lot
Posted on March 24, 2015 at 17:43
I don't think so, and other code in FLASH/ROM can read itself.
