2010-12-01 3:31 PM
Can I save an array of variables in memory after a power cycle
2011-05-17 5:17 AM
Can some one point me to the right direction ?
If you have a battery you could use the BKP registers, otherwise you could use a section of FLASH.
2011-05-17 5:17 AM
''you could use a section of FLASH''
There is an Application Note showing how to do this; ie, using Flash to simulate an EEPROM. Of course, you could just add an external non-volatile storage device...
2011-05-17 5:17 AM
Hi Clive1 and neil andrew,
Thanks for showing me the right direction. I am about to run the EEPROM example under I2C under ''examples'' and take it from there to my application. Cheers KishoreWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
