Bug? Cube4.5 and F0308 forgets Keil Flash programming algorithm
Options
2014-12-05 5:19 PM
Posted on December 06, 2014 at 02:19
Hi All
Bug?When building STM32F0308 Keil project with Cube 4.5 for , the ''flash programming algorithm'' assignment is lost each time and has to be re-assigned. This doesn't happen with F405 as I am using this part as well.Also I think this may apply to all Cube/Keil projects, the ''Restart and Run'' flag is unset each time the cube project is re-created.Jas
Options
2014-12-11 8:06 AM
Posted on December 11, 2014 at 17:06
Hello Jason,
The flash and debug settings are not saved at project re-generation and you will have to configure them each time you generate your project unfortunately. This is an enhancement for a next release. Best regards
