2014-01-28 11:27 PM
Guys,
I've tried : DAC/DualModeDMA_SineWave/main.c * @author MCD Application Team From Standard peripheral library, I can see it already on the osciloscope, how can I make it audible ? How can I adjust the frequency ? thanks2014-01-30 3:38 AM
No need for work around, a LM386 will work if used correctly. Did you add a low pass filter? Show the circuit diagram (else we are all just guessing what you've done wrong).
