''active write protected STM32 device detected''
‎2017-02-14 5:07 AM
Hi, I am working on ST STM32L151VB-A, I burned a loader which already worked for me, and since then I get ''active write protected STM32 device detected'' also on other application that worked fine.
when I try to connect via J-Link commander I get ''cannot connect to target''.
as I understand from:
''This can have different reasons as for example the application does disable the debug interface, re-configures the debug pins, enters some kind of low-power-mode or the security of the device is activated. In order to prevent such situations during the development process''
is this reversible at all? What can be done?
Thank you!
‎2017-02-15 2:45 AM
If pin BOOT0 is not directly connected to GND you can connect it to VCC in order to change the boot mode (see reference manual).
BR.
Danilo
‎2017-02-15 2:45 AM
BR.
Danilo
‎2017-02-15 6:34 AM
It worked!!! thank you so much!
‎2020-09-30 1:07 AM
I meet same question when using STM32F401RET6, using this way and can programming, but this Application don't run. please help it. thanks.
