Will connecting motor phases of hall sensor in the wrong order damage STEVAL-PTOOL2V1?
ADani.2
If I connect motor phases of hall sensor in the wrong order, what will happen?
Will be damage to My STEVAL-PTOOL2V1?
How can I attach pdf to a question?
4 REPLIES 4
Laurent Ca...
Lead II
Dear @ADani.2​
I move your text from title to description.
Best regards
Laurent Ca...
Laurent Ca...
Lead II
Dear @ADani.2​
Regarding connecting motor phases of hall sensor in the wrong order, is this a problem you have or a theoretical question?
Best regards
Laurent Ca...
Laurent Ca...
Lead II
Dear @ADani.2​
Regarding your question about attaching a pdf file, you have an icon at the bottom left of the grey zone on this page.
Best regards
Laurent Ca...
ADani.2
Regarding connecting motor phases of hall sensor in the wrong order, Motor is not spinning, marking on motor and on EVM are not the same, I am afraid to cause damage to EVM.
Thank you,
