X-CUBE-CELLULAR Update
NCatt.1
I'm working on a project with version 5.2 of X-CUBE-CELLULAR and there is an new version 6.0. I tried to download it and use it to update my project but I see that folders structure is not the same, thus updating my project is difficult. What is the easiest way to do that ?
Ronan GABOU
on st.com V5.2.0 + associated patch is available and the V6.0.0 is also available.
https://www.st.com/en/embedded-software/x-cube-cellular.html
Ronan,
5 REPLIES 5
Ronan GABOU
My suggestion is download and extract XCC V6.0.0.
Run the Cellular App example corresponding to your HW.
So you are sure your HW, connectivity and FW is up & running.
Replace the content of Cellular App with your application (you've written for V5.2.0)
Adapt the API call from V5.2.0 to V6.0.0
Rebuild and test your application.
Ronan,
Ons KOOLI
Senior III
Hi @NCatt.1​ ,
Can you please specify where did you find the new 6.0 version? Because I checked the ST website and did not find a patch for the new version.
Best Regards,
Ons.
NCatt.1
Hello @Ons KOOLI​ ,
I found the new version on ST website, about 3 weeks ago (this is my download time) but actually this version is not available today, on the same web page... Maybe the new version is not working fine ?
Ronan GABOU
Ronan,
Hello Ronan,
Ok I understand: the "Get software" button is for actual version (6.0) and "Select version" is for previous version (5.2).
Thanks,
Nathan
