VBUS sensing Dedicate ping, "USB FS upstream port in self-powered applications"
FMaro.1
Hi have the use a USB aplication with STM32L151CBT6ATR, but this uC have not a dedicated pin for VBUS sensing, how is the way to resolve that situation ?
I readed AN4879 and usb_20.pdf specification and not are cleare for me.
Much apreciate any solution
4 REPLIES 4
You can use any GPIO pin and ensure the voltage is sufficient before enabling USB, and trigger an interrupt when the voltage drops below a given amount to disable USB.
An this solution have a direct support for USB FS library code generated for STM32CubeMX ?
Not sure, probably not.
Thanks you for your answer
