USING UART PINS via USB FS not USB TO UART
arduo
Hi how can i use UART Pins via USB FS. I am currently using the USB TO UART connector on my devboard but how can i use the USB FS connection to make uart pins working?
I want to use uart3 PC10 and PC11 Pins but its not working with the baudrate if i connect usb fs but its working with usb to uart why?
Below pictures of the mcu and the dev board i marked the connections:
Thanks for everyone who helps!
Whoever get my problem solved will be rewarded thanks!
10 REPLIES 10
how do i link that to usart3 can you give me a code example?
