UM1721 Developing applications on STM32Cube™ with FatFs
We're planning to integrate a file system with the VENC_SDCard example for the STM32N6x7:
https://github.com/STMicroelectronics/STM32CubeN6/tree/main/Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard
We found Revision 3 of UM1721 Developing applications on STM32Cube™ with FatFs dated February 2019 and were wondering if that's the most recent revision of the document?
https://www.st.com/resource/en/user_manual/um1721-developing-applications-on-stm32cube-with-fatfs-stmicroelectronics.pdf
Will
Issamos
Lead III
Hello @Will_Robertson
Since it is the version on the ST website. I can confirm that it is the last version. I’m not surprised since the newest STM32 series support Filex instead of Fatfs. But you can still use Fatfs as a classic MW. For that, I suggest you to have a look at this repo.
Best Regards.
II
Issamos
Lead III
Best Regards.
II
Hello @Issamos ,
Thank you very much!
I hadn't known about
https://github.com/STMicroelectronics/stm32n6-classic-coremw-apps
that's an enormous help.
Will
If so, you may close this topic by selecting the answer of this question as best answer. This will give the answer more visibility on the forum for other users looking for the same information.
Best Regards.
II
