Transitioning from PR_SRC_Discovery to PE_SRC_Disabled is not happening
CZubi.1
I have a non PD battery pack connected to our SRC. Stack would keep sending SRC Capabilities and stay in PE_SRC_Discovery state. Timeout for Hard Reset or NoResponseTimer Doesnt seem to be happening as I am not seeing a transition to PE_SRC_Disabled.
Is there a way to disable from dpm_user end to cleanly get the PE out of Discovery state?
log attached.
4 REPLIES 4
Yohann M.
You can enter in the Disabled state in enabling flag 'PE_CapscounterSupport' as USBPD_TRUE in 'DPM_Settings' variable (defined in usbpd_dpm_conf.h).
Yohann
CZubi.1
Thanks Yohann. That fixed it for me.
Hi Yohann,
Is there a way to lessen nCapsCount?
Dear @CZubi.1​
No, nCapsCount is defined in the specification and should be set at 50. This is the value we set in our library.
Yohann
