STM32G071KBU6 can't found UCPD1_CC2 pin definition
Felix1
As title, I want to use STM32G071KBU6(GP version) desing USB PD function, but I can't found UCPD1_CC2 pin definition in datasheet.
Please kindly help reply this question.
Thanks.​
waclawek.jan
I don't understand the reason, but the GP versions appear to have pins brought out so that UCPD is basically unusable.
The footnote under Table2 in DS for the GP versions says:
One port with only one CC line available (supporting limited number of use cases).
