STM32F042K6 USB HID Library Size Problem
MSMorkan_R
I have created a CubeMx project for STM32F042K6. I am using following components:
  • USB
  • TSC
  • IWDG
  • GPIO
  • TOUCHSENSING
  • USB_DEVICE
I just defined the pins and tried to compile but compiler says FLASH overflows around 2.5K
I didn't even write one line of code. Then I realized USB HID library takes a lot of space (around 21K) on the FLASH.
How can I reduce this size? Is there anyway to use it as Keyboard+Mouse without using entire library? Or is there any 'Lite' libray for USB HID?
Hello
Change compiler optimizations for smaller code.
Hello
MSMorkan_R
Thanks! It solved the problem. Code size reduced to half (around 16K). Does this method has any side effects?
hello
When reduce size , depending on the code, results varies. May observed slower execution.
