Stack memory ?
antonius
Posted on April 17, 2017 at 07:51
Everyone,
Are these variables taking a lot of memory space on the stack ?
FRESULT fr;    //move to global        /* FatFs return code */
FILINFO fno; //move to global
DIR dir;     //move to global
#space #memory #freertos #stack
4 REPLIES 4
Posted on April 17, 2017 at 09:43
To be frank, I just say NO.
Those variables are usually taken on BSS region.
Posted on April 17, 2017 at 10:16
So what's the cause ?
The first task, the files can be played correctly but the next task,
it's only reading the file name and never played.
I don't understand why ??? variable memory allocation ? stack overflow ?
If I played without RTOS, it's working with all the directories and files.
Posted on April 17, 2017 at 10:47
Not being a specialist of RTOS, I guess RTOS tasks have their own individual pseudo stack size (properly sized up) or mecanics for variable visibility.
Posted on April 17, 2017 at 17:53
Doesn't it depend on where you allocate them and the scope?
If you don't want multiple threads treading on each other's data they should be local/auto
